    Dismiss Notice
New Sky router power consumption
Discussion in 'Audio Visual' started by DaveHerns, 2 Feb 2015.
  1. DaveHerns
    DaveHerns
    11 Nov 2009
    2,582
    Thanks Received:
    207
    Country:
    Going back to Sky after a bad experience with Virgin Mediocre.... I see the new router is marked 230v .2a =46 watts. The previous router was 12v 1a = 12 watts . Sky say leave it on 24/7 . Why are new routers less "green" and using more power ? Seems to go against all initiatives to be more efficient. Maybe I'll use the old router, it was good enough for what I need
  2. Sponsored Links
  3. big-all
    big-all
    12 Jul 2004
    18,849
    Thanks Received:
    1,476
    Surrey
    Country:
    your not comparing like with like
    you need to read the mains adapter for the 12v router
  4. winston1
    winston1
    11 Jan 2010
    7,002
    Thanks Received:
    532
    London
    Country:
    No it doesn't. You don't know the power factor so it could be anything from zero to 46 watts.
  5. Monkeh
    Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
    Don't confuse the maximum input rating with actual power consumption. There's no way it pulls 46W.
  6. DaveHerns
    DaveHerns
    11 Nov 2009
    2,582
    Thanks Received:
    207
    Country:
    I accept the 12volt one might use a bit more because of the losses in the power supply unit but why do they mark it .2 amp if as you say it uses less ? Doesn't a 60 watt light bulb use 60 watts ? I did have an argument with Panasonic over my plasma TV where the box was marked 180 w Efficiency rating C ( guessing these) whereas on the back of the TV it says 275 w . They replied it depends on how you use it .I'm still unconvinced. Going back to my router , surely it's "transmitting" all the time and the power consumption remains constant?
  7. Monkeh
    Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
    There's a power supply in the new one, too, it doesn't run off 240V. That's the worst case rating and is probably specified at a much lower voltage.
    Not remotely. If nothing is using it, it'll only wake very occasionally (relatively speaking.. we're talking about hardware which performs millions of instructions per second, here, so a delay of a millisecond is huge) to make a very brief transmission. The rest of the time it should consume next to nothing. Average power consumption over a long period is dominated by the power supply, and will be measured in very low single digits at worst.
  8. big-all
    big-all
    12 Jul 2004
    18,849
    Thanks Received:
    1,476
    Surrey
    Country:
  9. Monkeh
    Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
  10. Sponsored Links
  11. big-all
    big-all
    12 Jul 2004
    18,849
    Thanks Received:
    1,476
    Surrey
    Country:
    yes i understand that
    i went round all plug in items in my house and theres a label on all off them with
    off 'standby and on watts marked plus other values as appropriate if they have different settings
    i also measured all my led light bulbs so can choose the best and worst for consumption as some can use 2 to 2.5 times more power for the same light output
  12. DaveHerns
    DaveHerns
    11 Nov 2009
    2,582
    Thanks Received:
    207
    Country:
    OK I'll not worry about this new router and get one of those power meters for curiosity.
    Thanks all
  13. big-all
    big-all
    12 Jul 2004
    18,849
    Thanks Received:
    1,476
    Surrey
    Country:
    they are brilliant not all about saving money its about knowing when you can relax and not worry for example i used to worry about the washing machine and tumble dryer but the washing machine uses just over 1kwh per cycle and the tumble about 2kw so far cheaper than i thought
    indeed because i dont use the washing machine daily i actually worked out that a cycle uses less power from a cold fill than leaving it on standby for a week
    you can enter the cost off a kwh into the meter and it will tell you the cost over several hours or days
  14. big-all
    big-all
    12 Jul 2004
    18,849
    Thanks Received:
    1,476
    Surrey
    Country:
    also found out the sony flat screen tv in the front room uses 100w and the newer samsung both the same size uses 44w so i just switched the tvs round :D
    • Thanks Thanks x 1
  15. ericmark
    ericmark
    27 Jan 2008
    18,302
    Thanks Received:
    1,711
    Llanfair Caereinion, Nr Welshpool
    Country:
    I tried to work out what was using so much power with a plug in meter. But then I started to work out what it would cost to replace heavy users with more efficient models and I was coming up with 10 ~ 20 years to pay for the change and that was without fracturing in interest lost on money used once I did that then many items hit infinity with the time.
    The big on was fridge and freezer since they run 24/7 and it was a mine field as the internet sites use the price of the non frost free fridges which once you factor in the cost of de-frosting once a month or so are not as efficient as they first seem.
    This was repeated with many other items. With a free to air box on stand-by I could not measure current it used as so low. With the Sky box it used around 14W on stand-by. But the Sky box auto changed times when programs were delayed and meant I did not also need a VCR or video recorder running as well.
    I moved from Talktalk to Sky for broad band and it was the router which transformed how everything was run. The router power resulted in lap tops working in every room and all the temp LAN cables were redundant. All but the Sky box and the Blue-ray are now wireless. I honestly do not care if it uses 4 times the power of old system as the big thing is it works.
    I have only one complaint since going onto sky my caller ID has failed. It should work I have since Christmas logged three calls.
  16. Sam Gangee
    Sam Gangee
    24 Jan 2003
    1,875
    Thanks Received:
    284
    Cheshire
    Country:
    Fracturing is what you do if you break a leg. :confused:
    The word you want is "factoring".
    See http://help.sky.com/articles/caller-display
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
