I'm currently renovating upstairs rooms in my house and making changes to the upstairs sockets (moving some, adding new ones). I'm running new cabling and any existing socket is being removed from the existing ring main and wired with new cable - as soon as it has new cable it has no electrical connection.
When I've finished the new ring main will need wiring into the CU and a part p test carried out. For an electrician carrying out the connection and part p test, what is the best way to leave the new sockets? Each socket connected, faceplate wired and attached? My uncertainty is whether the electrician needs access to the wiring for inspection, or if tests are done via the faceplate?
Thanks!
Thanks!
