New windows and Door are draughty
Discussion in 'Windows and Doors' started by JustinScot, 13 Sep 2020.
  1. JustinScot
    JustinScot
    16 Aug 2016
    25
    Thanks Received:
    Country:
    hi,
    Ive had two new PVC windows and a door installed in the spring and now that the winds picked up I can feel a breeze :(
    I tried to adjust the little bolt thing it made it a little tighter but theres still a 1mm gap in the corners.
    And the rear door is worse, I can hear people chatting as they walk past the back.
    Windows:
    IMG_20200913_120352.jpg IMG_20200913_120403.jpg IMG_20200913_120502.jpg IMG_20200913_120511.jpg
    Door:
  2. Sponsored Links
  3. JustinScot
    JustinScot
    16 Aug 2016
    25
    Thanks Received:
    Country:
    How can i seal these?
  4. JohnD
    JohnD
    15 Nov 2005
    75,068
    Thanks Received:
    4,359
    Crossgates, Europe
    Country:
    Cook Islands
    is the gap between the door and the frame, or (very likely) the frame and the wall?
    use a smouldering joss-stick to trace the air movement.
    Or a smoker, if you know one and are prepared to let him enter your home.
  5. JustinScot
    JustinScot
    16 Aug 2016
    25
    Thanks Received:
    Country:
    It's between the window and the frame.
  6. JustinScot
    JustinScot
    16 Aug 2016
    25
    Thanks Received:
    Country:
    Is there supposed to be a rubber strip in here?
  7. Notch7
    Notch7
    15 Sep 2017
    26,100
    Thanks Received:
    1,824
    S. Uplands
    Country:
    no thats a drip groove.
    Upvc windows have 2 draught seals one on the frame rebate, one on the sash behind the stormproofing
    Upvc windows dont come with locks set up -they need adjusting for correct compression -look for the cam on the sash espag lock -and turn the that with a hex key.
    if you get noise it could be from the trickle vents
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
