- Joined
- 16 Oct 2017
- Messages
- 3
- Reaction score
- 0
- Country
Hi. Im face-lifting stairs with new full newel posts, base rails, hand rails spindles etc. I'm fine with doing the base rails, hand rails and spindles.
Been looking at the upper and lower newel bases (which I plan to replace with full posts, needs to be all oak. I have queries on removal of the bases before I start.
1) up stairs newel base moves a lot already quite easily in fact so should come out easily and unlikely structural.
2) down stairs one seems to have first bull nose step in the way. can see base is cut out and resting on 2nd tread. Seems to be only nailed from inside but could have a dowel into floor? No signs of side anchors, I've drilled out the empty plugged areas.
Also stairs are supported by a breeze block wall mid way (full width of stairs) and a 3x2 timber frame on the newel side.
Q. Hoping that first step could be removed out to give access to lower newel base for removal in opposite direction where nailed. To avoid too much cutting out of Base.
Pictures added below.
Advice/comments/suggestions all helpful.
Thanks in advance.
Thanks in advance.
