No earth on Light Fitting
If the light is double insulated - there will be a symbol like two squares one inside the other - then an earth bus not needed. Just term block the earth conductor
The item claims to have a ceiling rose.
This is what should be inside a ceiling rose.
What have you got?
Just two cable going into a small cased choc bloc. No earth on the metal case.
Sorry, so 3 wires from the ceiling, live, neutral, earth.
2 Wires in the lamp fitting, Neutral and live.
Ah yes it does have a sticky on the inside with two squares on it, one inside the other.
