Hi all, hope you can help.
My central heating is working fine, but i have no hot water unless the radiators are being used. I have operated the hot water cylinder stat, turned to max and the pump starts to run but the boiler wont fire?
Im not sure how to check the wiring. The 3 way valve is about 6 months old, replaced this due to being unable to shut the radiators down.
Once valve was replaced, radiators worked correctly.
Thanks for any help you can give.
