Balls come loose in the 3 port.![]()
If the ball had come loose ( virtually impossibility because they have a hole through them and sit on a shaft but... ) then it would be loose and both ports would be open.
The OP says there is not HW without CH so thats a control or motor valve microswitch problem or a failed or jammed motor valve.
Tony
