no return on new circuit
3 Jul 2006
Manchester
just had a loft conversion done-the electrician fitted 2 sockets and new lighting. I've since had to add an extra socket and found the socket I picked up from had supply to it but the return was just an uncapped live length of 2.5 going nowhere! Didn't even look like it has been cut-more like the end of the reel. So, do I get the guy back and risk him having to rip up new carpets/plasterboard to complete the circuit or live with a single cable supply where the greatest load is likely to be a hairdryer?
So he picked up the supply from a bedroom below, i assume? And ran a cable up to a socket, and left the return to the ring main just hanging?
Have a look in the socket he took the supply from in the bedroom. are there 3 cables attached to the socket plate? If so, it is safe to simply remove that hanging cable, and live with the single cable, it is an unfused spur, perfectly safe.
thanks for the reply.Yes, he broke in to the supply from the bedroom below but under where the new stairs now are-so impossible to check,but I seem to remember seeing 2x2.5 feeds (as well as the lighting feeds) going up to the loft in the new studded wall so I'm a little bothered as to where the rest of the return is!
you might like to give the electrician a call, and ask him what he's done, "for future reference", see what answers you get.
and ask him what he meant to achieve by hiding that socket where it is no longer acccessible - this is against the regs, though this may not be his fault - it should have been moved.
