I recently moved into a 1880ish detached house, and amongst the many problems there has been a smell in the downstairs bathroom. I first thought this was dampness as dampness affects the other side of the property but this doesn't actually seem to be the problem, and the smell comes and goes although is present most of the time.
It struck me today that there is no vent pipe on the outside of the house, and the other houses in the street of a similar age have these. The back of the house had an extension done in the 1980's and as this is probably where the vent would have been I wondered if it has been removed then. Around the same time a toilet was added along with a loft conversion, and again this would presumably have meant the existing vent would have been too low and plumbing would have been added above for this.
I am presuming this is not right, and could be the cause of the smell coming into the lower bathroom, but maybe I am missing something?
If this needs to be rectified, could a pipe be branched off the loft conversion toilet drain and vented straight through the roof.
Apologies if I am stating the obvious or talking nonsense here, I understand the principle of why vents are fitted, but have no knowledge of what various plumbing practices might be!
