    Dismiss Notice
Not enough space behind new light switch. Help (PICS INSIDE)
Discussion in 'Electrics UK' started by New2DIYing, 30 Nov 2013.
  1. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Hi guys
    I was replacing my old light switch with a new one and came into a bit of a problem.
    The old switch extends past the wall so has more space behind it whereas the new switch I tried to connect is flat against the wall.
    I tried for almost an hour and could not get the new switch to push against the wall flat. Hence I took it off and put the old switch back on.
    As the new switch is flat I am assuming the little extra space the old switch has lets it fit onto the wall.
    Is there anything I can do to solve this problem? From what I can see its the wires that are getting in the way!
    Or will I need to get a new switch that also extends past the wall?
    See pics below for the switches I have:
    New One:
    [​IMG]
    Old One:
    [​IMG]
    Thanks.
  2. Sponsored Links
  3. Sherbertlion
    Sherbertlion
    15 Jan 2008
    191
    Thanks Received:
    13
    Country:
    Yep either a different switch or cut out the existing back box and sink a 35mm deep box in, but there will probably be some making good to do afterwards!
  4. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Sadly putting in a new box is not really an option as the walls have just been painted. I guess I will take a trip down to B&Q and see what other switches they have on offer :(
  5. westie101
    westie101
    3 Jan 2011
    2,497
    Thanks Received:
    313
    Cumberland
    Country:
  6. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,192
    Thanks Received:
    2,085
    Oxfordshire
    Country:
    A common problem with flat plate accessories. :cry:
    And they look especially cr@p with a spacer like Westie has linked to.
    Looks like you're gonna have to stick with '70s brass, or dig out that wall.
    Sorry - its a zero option option.
  7. rjm2k
    rjm2k
    30 Jan 2008
    2,125
    Thanks Received:
    163
    Yorkshire
    Country:
    What kind of wall is it? Looks like it could be a hollow wall back box?
  8. Sponsored Links
  9. Johnmelad
    Johnmelad
    22 Mar 2007
    1,142
    Thanks Received:
    103
    Cumbria
    Country:
    Or really naff
    [​IMG]
  10. paulc2
    paulc2
    13 Nov 2013
    93
    Thanks Received:
    6
    Cheshire
    Country:
    Do they still have the part-used tin of fairly fresh paint?
  11. rjm2k
    rjm2k
    30 Jan 2008
    2,125
    Thanks Received:
    163
    Yorkshire
    Country:
    Assume there's an earth at that switch?
  12. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Yes there are three earth wires behind the switch. One is connected to the switch and two are sort of folded out of the way.
    However the one that is connected to the switch seems really free moving like it may be broken further down the wire hence is able to move up and down with ease. Due to this I may use one of the folded away earths instead.
  13. sparkwright
    sparkwright
    20 Aug 2009
    8,377
    Thanks Received:
    1,044
    Dorset
    Country:
    ALL earth wires need to be intact, and ALL joined together, and must be in contact with the metal switch front, and ideally the back box if metal.
    NOTHING else would do.
    Any earth wires not used must be verified to check they are actually earth wires.
    With the power off, please send photos of what you have there.
    It may be an idea to use a plastic switch until everything is satisfactorily checked and put right.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
