Not understanding drill bits
27 Jan 2008
Cumbria
So I'd appreciate some help from anyone who knows about drills and drill bits. I've ordered a drill bit that 600 millimeters long but it doesn't have a circular end so it won't fit securely into my drill. The chuck doesn't tighten as well as it does with a fully circular drill bit.
You can see in a photo the drill bit that doesn't fit securely on the left and an example of one that fits perfectly on the right.
I can understand that the drill bit simply isn't going to fit but I've had this a couple of times in the past and haven't been able to find an answer.
It's obviously time to upgrade my drill but can anyone tell me what type of drill I need to buy in order to be able to accommodate both the types of drill bit in the photo?
You appear to have bought a SDS drill bit
SDS: The original German was "Steck-Dreh-Sitz" meaning Insert-Twist-Stay. As the bit evolved, it has come to be known as a Slotted Drive System or Slotted Drive Shaft.
Special drills use them for a percussive hammer action with/without rotation of the 'bits'. https://www.machinemart.co.uk/c/sds-sds-and-sds-max-drills/ has some examples
Interesting about the German origin . Like the beetle KDF vagen Strength through joy, A.H's slogan ;)
Thanks guys appreciated. I ended up heat gunning a cable tie onto the end...did the trick.
A proper SDS drill is usually more powerful (hammer and torque) than a typical hammer action drill.
They may be equipped with a clutch to reduce injury to your wrist.
Judging by the photo, and the shank of the SDS bit, I'm guessing it's about a 12 to 15mm diameter.
A SDS drill would be preferable.
There are two sizes of SDS. SDS at 10mm diameter, and SDS Max at 18mm diameter.
The larger size are usually used for the large 'Breaker' type machines.
This was the only tool available when I were a lad, and there was no electric available:
