Require some clarification please.
i was asked this scenario.
a homeowner had some unauthorised works carried out on his property ie room in a roof and external metal staircase to the rear of the property to the first floor.
The homeowner ignored threats from building control and eventually a section so n so was served to remove the unauthorised work within 28 days.
Now the staircase is well under 900mm wide so they have agreed to remove it.
now the room in the roof has a radiator and sockets. It has been plasterboarded and floorboarded without any insulation or soundproofing also has a skylight window.
no staircase to the room yet just a temporary ladder.
the homeowner has agreed to remove radiator, electrics and install a pull down ladder for access.
buliding inspector is adament to remove everyting ie floorboards, plasterboards, electrics and then close the hatch.
the homeowner as repeatidly stressed that he will use it as a storage only.
Any views on this can the building inspector do this.??
