Hi
Currently we have a fan assisted flu gas fire. There is an FCU about 3 feet away from the fire (for the fan in the fire) next to a double plug socket. I have not looked but guessing it's a spur from the ring main. We are replacing the fire surround and the wife mentioned one which has low voltage lights on the underside of the surround (pointing down towards the fire). Is it possible to connect 2 cables from the FCU, the current one for the gas fire and a new one for the feed for the lights in the surround? If this is not permitted, what is my best option for getting power for the lights. There is another plug about 8 feet away on the wall perpendicular to the wall which the gas fire is on. If needs must, I could take a spur from this to a new FCU, then to the lights, but it would be easier, less destructive to take feed from the fires FCU.
Thank you.
Thank you.
