Jurgen one tip that will help is to buy/get two extra guides for your pipebender (22mm&15mm)and cut them in half (file smooth the cut end like exsisting) you can get round tight tricky bending situations with these
howy1 said:Jurgen one tip that will help is to buy/get two extra guides for your pipebender (22mm&15mm)and cut them in half (file smooth the cut end like exsisting) you can get round tight tricky bending situations with these
I've never had reason to try it, but it sounds like a reasonable idea to me Mark - if it works for you then do it.doitall said:howy1 said:Jurgen one tip that will help is to buy/get two extra guides for your pipebender (22mm&15mm)and cut them in half (file smooth the cut end like exsisting) you can get round tight tricky bending situations with these
The Asylum taken over
one thing jurgen will learn over the years is to keep an open mind
Ok howy1 since you sound as though you may have been serious with the above idea
Since the guide is shorter than any length of pipe you will bend please, explain the reasoning behind the theory.
Balenza said:doitall said:howy1 said:Jurgen one tip that will help is to buy/get two extra guides for your pipebender (22mm&15mm)and cut them in half (file smooth the cut end like exsisting) you can get round tight tricky bending situations with these
I know where he is coming from.
Not a bad tip especially for doing full passovers straight through the A frame in one go.
It allows you to push the slide further back without having to wrestle with the tube stop or the spud as I used to call it.
Balenza said:Not a pipe fitter. Just stating my findings thats all.
But since you ask I would probably use the on site threading machine.
Failing that I would just weld the whole lot up solid.
Job sorted. Right ?.
If I am wrong then I can go to a different forum and state my findings after you have corrected me.![]()
