NYY-J or 'Tuff Sheath'
2 Dec 2004
Hi, Im going to be having a new circuit installed for power to an outbuilding which initially will only have lights and sockets but eventually might be used to home batteries and a hybrid inverter.
So Im thinking 10mm2 cable for future proofing initially on a 40A MCB which already exists in the consumer unit.
The run is fairly short, under 10m in total. Most of it can be clipped to an external wall or run in conduit on same walls. However there is a short section of approx 1m which needs to run under a rear pedestrian gate access. I was thinking to use 32mm ducting in this part, which will be run in a small trench then concreted in.
Been researching and I think SWA is overkill for this. I like the look of the Doncaster cables Tuff Sheath cable, but it seems hard to find. I could also go for NYY-J cable.
Is it worth holding out for Tuff Sheath, or is any NYY-J cable going to be good enough for this application?
I'd go SWA if its buried.
Im trying to keep bend radius down because its quite tight near the gate and in through two solid brick walls as well. I could gland and terminate externally into an adaptable box externally then take the inner cores through but then that's an extra earth cable that needs running too at both ends. All seems overly complicated for a 1m run under a pedestrian gate. Anyone looking will see the cable ducting exiting the ground literally at both sides of the gate so its not like it will be a hidden cable.
There was a Dutch NYY-J cable which had a copper wire against the steel braid, but I have found so many where the earth braid has failed, and left with the problem of how to get around it, and with domestic, I have seen homes go well over the 10 years between EICR so it would be easy to find there is no earth.
So I would also go for SWA, but the question of earthing has to be considered for any out building, the the IET report is now a bit outdated, but it does point out some of the problems.
Today what the out building is made of matters, metal buildings can be regarded the same as a caravan, where TN-C-S is no longer allowed, and with solar and batteries, it is common to have a back-up, so essential items keep running with a power cut, clearly for this an earth electrode is required, and likely also more than one cable.
So the cable duct will allow easy alterations, it was not that long ago when I could have fitted solar panels to my shed, today the rules would not permit it, too close to the boundary and made of wood. Even the solar I do have, today likely the batteries could not go where they are now, so there is a problem future proofing as one has no idea what the rules in the future will be, so ducting does leave the ability to modify easier than with SWA, but I would simply use SWA and lay more cables latter if required, at 75 I have over my life tried to prepare for the future so many times, and by time I have come to use it, something has changed so never did use the cables etc I have planned in the past to use.
The thing with SWA is bending it through the brick wall of the house. I want a neat finish, not having to chip away chunks of brick inside and outside to get the bend through.
I could terminate in boxes on the outside and then run separate cables inside but its additional terminals then.
Im trying to keep it simple and neat.
Its a fair point. I don't know when I'll put batteries in there, it could be years or never. Maybe I should just run some 4mm as that will be enough for now and maybe for ever if I don't do anything else with it.
Or 6mm as suggested above.
6mm will take 50 amps, unlikely it'll ever see that. When you're drilling through the wall you want to angle it upward (if drilling from outside to in) so that water can't track into the wall. This also means less of a bend on the cable when taking into the wall and providing you can bring it up on the other side should be easy to keep neat.
Don't concrete it in - cover it with bit of longitudinal drain cover, then it's not buried.
H07RN-F?
H07RN-F?
Don't think that's suitable for direct burial. Really more of an extension flex. I'd always go armoured unless there's a good reason not to
Edit - just read the first part of the post rofl
