In November I paid to have a solid oak floor laid in my home. The area of flooring covered included one room with an old ceramic tile floor which had been down since the 60's and an concrete floor in an adjoining extension I had built in the early summer.
Installation consisted of pouring levelling compound directly on the old tiles (but not on the concrete area) on day 1, on day 2/3 installing the new boards and skirting. He did not prime the floors or do any sort of floor preparation. He also didn't perform any moisture testing.
Things have since gone wrong. There are multiple problems which only affect the boards laid over the tiles, the boards on the concrete base of the extension are (currently) fine. Problems include:
Here is a more detailed account of how the installation proceeded:
On the morning of Monday November 23rd 2015, I was working on my laptop in the Livingroom when I overheard the owner telling ‘Dave’ to mix in “some of the **** stuff” since there wasn't enough of the 'good' levelling compound for the whole floor. Presumably he also watered it down excessively so as to have enough for the whole floor.
On the night of November 23rd 2015, I was so concerned at how wet the levelling compound was that I photographed the floor and also took a short video. The media clearly shows standing water in some areas of the floor and also an area which had disintegrated. Of course the initial drying/curing time for levelling compound is between 2-4 hours. Something seemed to be wrong.
The following morning (November 24th 2015), I looked at the floor again. As previously stated, large areas were cold and damp to the touch and the compound was dark grey, indicating to me it hadn’t dried. I took more photos and also photographed the two different brands of empty levelling compound bags which were left in the house. I also informed 'Dave' of my concerns but trusted his experience and opinion when he said it was ok to proceed.
I've since looked at the installation details of the two brands of compound used:
Setcrete – Universal Floor Levelling Compound
As far as I'm concerned he has made a complete mess of the installation and if he doesn't fix it, I'll take him to court.
How do people advise I proceed?
Does anyone know of a reputable flooring contractors near to Chorleywood I could call for a professional opinion?
Any assistance would be greatly appreciated.
- Serious buckling of the floor affecting an area of ~2sqm, where the boards had completely detached from the floor beneath.
- Various areas throughout the floor where the boards have detached from the floor beneath.
- Extensive ‘cupping’ of boards throughout, where moisture has caused the underside of the boards to expand.
- Application thickness 3mm to 6mm
- 3 hour walk on time
- “Setcrete Universal is not suitable for use when bonding solid wood flooring.”
- “Floors should be primed to ensure good adhesion between levelling compound and substrate”
- 4 hour walk on time
- Priming
“Priming with SikaLevel®-Pro Primer is essential to ensure good adhesion and reduce air release from the substrate.”
“For very smooth e.g. steel trowel finished surfaces, grind surface prior to priming.”
- “Use only on cementitious substrates."
- “Concrete substrates must be prepared mechanically using abrasive blast cleaning or scarifying equipment to remove cement laitance and achieve an open textured surface.”
- “Make sure the moisture content has achieved the required value for the application of the coating product.”
- The concrete substrate must be sound and of sufficient compressive strength (min. 25 N/mm2) with a minimum pull off strength of 1.5 N/mm2.
