Oast house, problem calculating
14 Nov 2004
Kent
Not sure if it belongs here, but I'll give it a try and see where it ends up.
Ok guys, need your help with a calculation (not good at 'strange' math things).
Oast house has diameter 4.8 meter, how many square meters is that?? Please?
radius is 2.4m
area is (pi r) squared
so approx
(3.141582 x 2.4)2
(7.5397)2
but if you allow 15% wastage because it is round
call it 65m2
Thanks guys.
I'll make that 57 sq m ? Starts to look like a great job then (not sure hubby would be so happy though ;-))
Beg to differ on the position of JohnD's brackets, as that implies you do the pi x r first and then square the whole lot, whereas you do the r-squared first and then multiply by pi.
Answer is about 18.1 sq.m though, but I gues you need to allow a lot more for offcuts than usual as you are not going to have square ended boards that you can just start the next row with.....
(Imagine it was a 5m x 5m square, that would be 25 sq.m. Chopping the corners off is not going to magically make it 57 sq.m, is it now.....)
how I wish I could remember pi.
..3...1....4....1...5.........8..........2
You mean pi (r 2)?
:oops: :oops:
pi ( 2.4 x 2.4)
3.141582 x 5.76
so about 18.1 plus (lots of ) wastage
stupid boy John.
That's the feeling I had too. 4.8 x 4.8 = 23 sq m, 'chopping' off a bit for the round area and including extra waste makes 20 sq m.
Wasn't that far off then (and not as 'stupid' as I thought)
but do bear in mind the answer is the exact area in square units.
it does not take into consideration off cuts for the material you "can not use"
