OCR?
29 Oct 2012
Bristol
Hi Chaps, I am a building contractor after some advice - i've just engaged with a new plastering subcontractor and had a question to do with OCR.
They start on Monday and after asking me for my spec (stainless beads and 2 coats of sand and cement render), i turned up to find all of the materials had been delivered and they are using this webber OCR product - all I can gather is that this is a 16mm 'One Coat Render' as the acronym suggests!!
Should I be questioning them about this, i'm assuming it won't go on in 2 coats?
I just want to make sure that i'm not being short changed. Also, will one coat with waterproofer be good enough?
Thanks in advance...
weber.rend OCR is a range of proprietary renders based on Portland cement, lime and sand. They are supplied as pre-blended dry powders, which require only the addition of clean water to provide a comprehensive range of renders which comply with the mix designations and specifications of BS 5262 and BS 5492. A lime-free version for tiling, which conforms to the requirements of BS 5385 is also available.
Formulated to comply with British Standard mix designations (see technical data)
Resists the penetration of external water and has excellent weather resistance and durability, whilst allowing the structure to breathe
Factory controlled production to give a consistently high quality product
Give the same final appearance as traditional cement and sand renders but in significantly less time
Non-combustible (Class 0 fire rating when applied to non-combustible substrates)
All surfaces must be sound, clean, dry and free of any material which may impair adhesion.
Scaffolding must be independently tied to allow for uninterrupted application. Any faults in the structure, particularly those which may lead to moisture penetration must be rectified.
Poorly keyed surfaces, for example smooth concrete, or substrates of uneven or high suction should be prepared with weber.rend aid.
Mask around the areas where material is to be applied. Masking tape must be removed before the material has dried out.
Expansion joints should be included as required by the substrate and carried through all applied materials.
Suitable specification clauses, including specifications for difficult or mixed substrates are available from our Technical Services Department.
Note: In many cases rendering applied to expanded metal lathing is more prone to cracking than when applied to dense masonry. To reduce this risk, lathing must be fixed strictly in accordance with the manufacturer's recommendations and relevant codes of practice.
weber.rend OCR should be mixed with clean water at a rate of approximately 4 - 5 litres per 25 kg bag using a tumble mixer or suitable drill with whisk attachment. For best results, use as little water as possible and mix to give a workable consistency.
Note: weber.rend OCR may stiffen on standing. Re-mix product to regain workable consistency but do not add any more water.
To avoid dampness and discolouration of finishes rendering should be avoided below DPC or within 150 mm of ground level.
weber.rend OCR should be applied with a hawk and trowel in a one coat operation, then ruled level. On low suction backgrounds a first pass may be necessary prior to building up the full thickness in the second pass.
Render thicknesses are as for traditional materials.
External render approx. 16 mm for sheltered to moderate exposure or 20 mm for severe exposure.
Internal render approx. 8 to 19 mm.
Tiling approx. 8 to 20 mm.
Thickness should not exceed 25 mm.
Finish as required. For plain face finishes rub up in the normal way as the render begins to pick up. Other appropriate fishes may be achieved by suitable means.
Cure for 2 - 3 days before over coating.
During rapid drying conditions such as hot climates, curing with a fine spray of clean water may be necessary.
Protection
Protect from unfavourable weather conditions during application and early curing.
Good practice
Do not apply:
If frost is forecast within 24 hours of use
In damp/wet conditions
In temperatures below 5°C or above 30°C
On elevations in direct sunlight or where the substrate is hot
If there ordeing OCRand NOT sand/cement an its same or better price CRACK ON mate happy days you got good guy there keep hold of them.
if the rates are good on the sqm and it turns out good..
then dont bother questioning them just sie back and let them do the bizzo
we use CR some times with PVC beads look good sponge finshed or trowel finished.
we have used acrylic bucket coat over the top or even tryolean!!!
its good stuff is can be put on in 2 coats
most the time 2 passes wet on wet or one coat.....
Cheers buddy - yeah I didn't mean short changed on money, I meant quality, I was happy with their price and they come recommended.
So judging by your response its a good replacement.
I suppose its not far off of £25 per sqm supply and fit
Although I asked for stainless beads would the plastic be better?
each to there own on beads i like PVC beads I find there abit cheaper then ss beads and take more a beating if bucket coat or painted 9/10 youll be able to match the colour of the finish with the beads
PLUSS side if knocked your not going to see a ss bead
and there easy to fit and cut
if your using OCR a lot there probs getting It for about £9 a bag
We are charging £30 m2 for monocouche supply & fit with full mesh coat
OCR isnt monocouche it is in a way but its not coloured like pral m or parex Krend ect it still need painting bucket coat or rought cast
