I had a door contact fail on the alarm, it was sticking closed, giving it a tap released it so I knew that needed replacing.
Before I could replace it I forgot it was stuck and walked past setting off the alarm by the one of the PIR's, ever since this happened that PIR is showing as active on the panel (light on when setting, beeps 7 times for that zone) and I have to omit it to set full.
I assumed I was unlucky and the PIR has failed, but replacing it gives exactly the same problem. Tamper works for that pir, and a walk test shows it detecting okay. ( I replaced the door contact which solved the original problem)
Any ideas what might have gone wrong?
Cheers
alarm=Texecom Veritas R8
old pir=colt quad, new =texecom reflex quad
Cheers
