oil boiler
23 Nov 2005
Lincolnshire
does anyone know the difference between an eh nozzle and a h or a es and an s??????
if you cant get one will the other be ok???
the "e" series nozzles are for kero only. not 35 sec.
bottom line is..its a hole squirting oil...cant see the fuss.
so in answer to your q. if youre on 35 sec oil . no
if on kero (burp) yes.
Since the different oils have a differing viscosity I would assume that a different jet size would be involved if fitting the wrong type.
In any case the whole boiler would have to be set up from scratch.
the e series are for kero.
what you do with the other types of nozzle.. ie with kero or diesel is up to you.
you cloth eared bint.
e = enhanced, this has a 5% tolerance compared to the 15% tolerance of the standard nozzles. h = hollow cone, s=solid cone, a = Delavan's code for hollow cone. To say they are just a hole squirting oil indicates a certain knowledge level.
You could use google, which appears to need a lot of effort, or you could look here for starters.
they are just a hole for squirting oil.
jeez ....its the simpsons.
whats ya prob oilman...?
Of course they are, just keep taking the tablets, and hand in your oftec registration. Just glad you're not setting up my boilers.
swelec said:
wilhelm said:
ahhhhhhh the cracken awakes :wink: :lol: :lol: :lol:
put me out of my misery
I have heard this expression before but a search on google leads nowhere
That's 'cos it's spelt kraken :roll:
