background up unitl two hours ago fully functioning system no problems
CH is a vented gas indirect using
Wikes LW60ci
Grundfos pump p/n595 25600 pc 0246 ip 44 class h max 10 bar three speed.
Channel plus xl h21 timer and honeywell thermostat.
Noticed that the heating wasn't on when I got in from work.
restarted the timer three way valve states
Thermostat light comes on boiler does nothing
test for power to the pump didn't seem to be anything
everything else seemed to test for power and function ok.
I'm no CH engineer and probably broke a million rules but to test if the pump had died I disconnected it from the junction box having noted that it take mains voltage I added a plug set everything to full and on and plugged it in. Hey presto everything came to life.
so now I'm really confused re wired the pump back and it does nothing.
any ideas guys would be really apreaciated
Wikes LW60ci
