Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hello. I blown a fuse the other day trying to install an extractor fan . . . I have a consumer unit which uses fuses which is a length of wire between two pieces of metal. This doesn't strike me as up to date. Does it need updating. Is it expensive?
Not necessarily but it would depend on the state of your current installation - just ensure that a full Periodic Inspection Report is completed before a new Consumer Unit is fitted.
Yes, well, serves me right for being tight doesn't it . . The wiring is sound. I think I would like to update it to one which just has a switch to flick once it has been tripped (not that it will happen again under my own duress). Thanks.
There is nothing wrong with the consumer units in general, but if the CU/Fuse box is of that age and the cables are the original ones, you could be due for a complete upgrade. The problem you will have, is that it is highly likely that this type of CU has no RCD protection and when adding or altering circuits, there is a big chance that the addition/altered circuit will need to have RCD protection.
Possibly, but without looking at the whole installation that shouldn't be taken as being likely, by itself. Wylex rewireables were still being installed widely in the 1980's, for instance.
If in the loft, then it's outside the defined zones for a bathroom as per BS7671 and as per the quoted definitions for the building regulations. The installation of a fan would still be notifiable work anyway, if you're worried about such things.
