Hi, I have an old electricity meter with 3 huge fuses on a board next to it that takes up more space than the meter itself. 2 wires exit from the meter to black boxes the size of fag packets before a wire exits from each to the consumer unit.
I have a guy coming from the elec company to replace the meter on Friday (took 4 phone calls!) but I'm concerned about the age of the fuses and wiring.
My questions are:
1 - Should the fuse board with the 3 big fuses be replaced with a modern more compact fuse?
2 - Should the 2 fag packet size boxes be done away with?
3 - Should an isolation switch be placed between the board and the consumer unit?
4 - If the answer is yes to all, or any, of the above, will the guy replacing the meter automatically assess the present wiring configuration and upgrade as required.
Any help would be much appreciated.
Cheers
My questions are:
Cheers
