OLD SCHOOL DIY,er reqs pushfit / flexi help
29 Sep 2009
Middlesbrough
Hello - Am fitting a new bath , the type with taps in the middle and not at the end . I need to know if I can join these new fangled "pushfit and flexi pipe,s" straight on to the old 22mm copper supplies.
I need to go about 3 ft ,Ive only ever worked with copper pipe most of my life.
If its not possible I,ll just make up some pipes and solder the job, but if I can - Whitch brand / type / make do you reccomend , and whats your advice /warnings etc on fitting copper to plastic. ?? any help gratefully received.
If your competent working with copper, I’d stick with that; I’ll never have push fit or plastic in my own property.
If you are going to attach pushfit to existing old copper, make sure the pipes are 15mm or 22mm.
Older copper may be 1/2" or 3/4", and out of spec. to connect with pushfit.
(1/2" is close to 15mm, but the size difference will probably be outside acceptable limits for pushfit. 3/4" is obviously smaller than 22mm)
If you have the kit and the ability, use soldered fittings. There is probably little difference in price, they have a proven track record for reliability and longevity, and they look neater too!
If you do go for push-fit the ends of the copper pipe needs to be free of burrs, preferably cut with a pipe cutter.
