="kaijun";p="1402962"]In one of my rooms, heating doesn't work this year.
Has it ever worked? Sounds as though the system has never been balanced. Maybe you have a by-pass valve that is open too much, this would allow water to return to boiler instead of going through your problem radiator, especially if the radiator is furthest from boiler.
What about the lockshield valve on the other end of radiator, if thats closed, then it wont heat up.
Have you tried closing the other radiators so all flow is to the problem radiator.
