Oops,my wall moved!!!
24 Feb 2009
Gloucestershire
Advice please.....................
I have a single story extension, with a flat roof.
While maintaining the fascias, I propped the ladder against the bricks.
In a couple of places the top few courses of bricks have pushed in 1/4 inch at most!!!! :cry:
The wall is in dire need of re-pointing (should have done it sooner :oops: ).
What course of action should i take?
Thanks, Matt
Repointing :shock: unfortunately my friend, it sounds as though you may require a little more than that! Bricks should never move under the weight of a ladder & it means there is now no mortar bond between the affected brick courses & just repointing will not sort it out. There may also be something amiss the roof support & ties as the weight of the roof should stop it moving.
thanks for the reply.
i know 'more' than pointing is now required!!!!!
i was simply stressing that if the pointing had been sorted sooner, i wouldn't be in this situation now. :oops:
what i was wondering was what to do now? how much of a rebuild is needed? do i have to remove the roof?!!!!!!! :(
Unlikely, but you may need to remove the fascia or soffit in order to access the masonry.
The uppermost courses of external brick on most houses is a weak spot, but not so weak as to simply push off.
The weight of the roof, whether it is a flattie or pitched generally bears down on the internal masonry, so it would not be difficult to belt them off with a hammer. Your bricks must be bonded with sand only! :shock:
It could actually be left as it is, and it would not be a big issue.
Otherwise just relay them
What will be required to sort it out is difficult to asses without seeing it & I would suggest you get someone “competent” to take a look at it. It may be just the top few coarses that need relaying but it depends on the overall condition of the mortar bond & the stability of the wall itself; the internal block skin (assuming you have one!) may also be affected. It is possible to knock out & rebuild the entire wall without disturbing the roof but it will need propping. I would be unhappy to leave it as it is; it can only get worse, may lead to problems with water/damp ingress & may even be dangerous if the wall itself is unstable; you also need to establish if & how the roof is actually tied to the walls!
