We've moved into a house where the previous occupiers used to have an open fire in the living room. They had a modern stone fire surround fitted and had the chimney swept regularly, and from memory they used oval coal as the fuel.
We would now like to do the same and will shortly buy one of the cast iron type stoves from B&Q or alike - think they're about £40. The question is, can we simply buy the stove, put it inside the fireplace and start burning wood/coal?
Do we need to do anything else, or is it as easy as it sounds/looks - just stick it in the fireplace, light the wood/coal and away you go?
Worried about fumes entering the living room.
After a bit of hunting around, whats the difference between a log fire and stove?
All I'm looking for is a grate type thing where we can burn wood and get a bit of warmth.
The old fireplace used to house a back boiler but this has since been removed and a modern boiler is now fitted in the kitchen. SO, I assume there would have been a gas flue/liner fitted inside the chimney. For the previous owner to have been using a log fire in there would that flue have to been removed?
Back to top
___________________________
lynda, moderator
please note forum rules, item g
Back to top
lynda, moderator
