Have just moved into a 30's detached, and starting from ground up with CH as old boiler and cylinder are broken beyond repair.
The foot print of the building is square. With 4 rooms to make the square with staircase in the middle. i.e. double fronted.
We are doing some minor building works to knock through and create an open plan L-shape with only the front right room remaining as a sealed room. i.e. go in the left front room and you can walk all the way around to the kitchen in the back right.
Regarding the open plan area: the front left room has original wooden parquet; the 2 rooms across the back of the house will be tiled.
We'd like UFH across the back of the house under the tiles but to keep costs down we plan to keep radiators in the front room.
Thinking about heat transfer between the spaces in the open plan L-shape, the heating lag on the UFH, does this make sense or should we go all UFH or all radiators?
