That looks great. Again, a very neat job.
But I thought the idea was to open up to the concrete lintel - is there a new reason for this height dimension?
I've already knocked it all off as it sounded hollow (blown from wall) what kind of finish Will sand and lime give? I want smooth plaster type finish.Its best to render chimney breasts in sand and lime 3:1 mix or say Dricoat with a remedial finish - the earlier reference to gypsum was to inside the fire opening but it applies to the whole breast.
Why, because its a barrier to soot penetration.
However, there's no need to knock off all the plaster on the c/b unless its required?
You skim the S&L with a Remedial finish such as Limelite.
Yes.
No.
Scratch on a very tight first scratch coat.
Any sign of amp or salts use plastics angle beads.
Mix 3:1 or 4:1 but dont mix it too stiff.
Mix half a bucketful at first, slightly sloppy, and see if you can trowel a tight scratch coat on.
Then fix the angle beads at outside corners, & let them dry on before applying the floating coat.
Take out suction as you go.
So you are using stop beads not angle beads?
Is it Limelite finish?
Mixing a little finish powder with the S&L fixing
dabs will allow for a quick set on the beads.
Use dabs to fix the all the beads - 15mm and 20mm stop beads are available.
There is a Limelite backing plaster and a Limelite finishing plaster - which do you have?
