Osma > Marley > Hunter Solvent Waste Compatability
1 Oct 2008
Wiltshire
I've got 32mm Osma solvent waste installed.
Wondering if I have to stick with that or can I use any of the other makes?
I know some measure from internal diameter while others use external.
Any one know of compatibility chart?
never had a problem mixing solvent weld.
only if you mix pushfit with solvent etc they don't match.
Solvent weld pipe and fittings are usually all interchangable- it's push fit that is a pain in the RRR's
