Outdoor kitchen roof epdm
19 Feb 2020
Thinking of doing an outdoor kitchen with an EPDM roof and just want to run this by everyone for guidance/advice for building it
Theres an excisting 2.1m high block on flat with stone faced wall. A 4x3 wall plate secured on top with w/p straps every mtr and express nails every mtr in between the straps spacing.
3m out from the wall will be 150x150mm post shoes bolted(or resin) to concrete pads of 750mm x750mmx750mm for 150x150mm treated timber posts. 3 off them. There will be a 9x2 secured to tge 6x6 posts with 180mm m12 coach bolts.
There will be 6x6 or 4x4 diagonal bracing attached to the 6x6 posts and 9x2 with 150mm 6.7mm screw
6x2 raters at 600mm centers screwd into the 9x2 in 3 places at the front and secured on the wallplate with truss clips.
18mm Marine ply screwd into the raters with 5x50mm countersunk screws.
Epdm roof covering with all the flashings. Guttering on the back end of the roof.
Im in two minds to keep the rafters flat and add firrings on top or cut the rafters at whatever angle it needs for the correct fall.
Also, screwing the 6x2s to the 9x2. Is 3 150mm structual screws enough . One 25mm down from top, 25mm up from bottom and one in center. Same as the other side, truss clips ok ? Main worry is wind uplift. Its not an exposed site but in the height of winter, it can still get windy like most places so wqnting to run these fixings by yous for advice. .
