i am trying to replace an outside light, it is an elstead az/le7. on the outside of the box it says "this fitting requires two separate electrical circuits", however inside the fitting there are only the connections for the usual N E and L. The previous fitting worked fine, the only difference is this one has a pir sensor. The only other connection inside the unit is the one from the sensor to the bulb fitting itself. Here is the question, how do I put two circuits, and why? Does it just mean I can bypass the sensor with a separate switched feed for overide purposes or does it mean something else. Any comments
