Outside light
26 Jun 2007
Aberdeenshire
Hello
I'd like to install a low wattage (42w) security light outside; about a metre from the internal porch light. The internal porch light has a single cable going into the ceiling rose which then runs down into the wall studwork from the roof space (single storey extension). I can't see a junction box, perhaps its in the wall. Can I run a new cable from the connector blocks in the porch ceiling rose, throught the external wall to the security light. Presumably both lights will then run off the same switch.
Cheers
happyhermit
It would have been wrong for someone to put a junction box in the wall but that doesnt mean it hasnt been done :)
As for connecting at the ceiling rose, they dont usually have enough spare terminals to feed an extra light, and I think its considered a no no to put two wires in one terminal at a rose.
Regards
Thanks lazygit
How about putting in a junction box before the ceiling rose to take a spur off to the outside light.
Cheers
Theres no reason why you cant put two conductors into one terminal. Separate ones are better though. A proper ceiling rose will have spare terminals if there are only two wires (plus earth?) feeding the porch.
You can do what you suggest. Just remember that the security light will only be on at the same time as the porch light.
Dont forget to earth the security light!
With loop-in wiring, the rose is the junction box. You'll soon find out what you've got if you have a look in it. (Power off, not just the light.) If there are four terminal blocks in there: two for the light itself, one earth and one other, you should find that the one other is permanent live. You can use this one, the earth and the neutral (one side of the light) as a supply for your outside light on its own switch. :) :) :)
But if the above is true, only a single cable, that cable will be neutral and switched live, which will mean the external light will only work if the porch light is on
Thank you all for the replies, much appreciated.
There is a single T&E cable coming through ceiling to the rose, red, black and earth. These are connected into blocks with the brown and blue pendant wires. Earth has its own block. There is a spare triple block in the rose labelled loop with no wires in it.
So I can just pass some 1 or 1.5mm T&E through the ceiling and double up into the N, L and E terminals? Then both lights are controlled by the same switch.
My other thought was cutting the wire in the roofspace and putting a junction box in there. Any advantage to doing this?
Cheers
HH
you have already said that, you still get the same answer.
but bear in mind as there is only one cable at the rose the external light will only come on when the porch light comes on
Beg to differ
My question was is there an advantage to me installing a junction box in the roof space. That has not been answered. I already stated that I thought the junction box was in the wall.
HH
no lines for me, (is there not an option for a poke in the eye with a sharp stick?) i am only pointing out to the op what he has already said, so i thought it a good idea to point out the obvious
A junction box must be accessible - it probably wont be in the roofspace. Use the ceiling rose.
