Hi
I have been having problems with my outside tap and hose connection since moving here 6 years ago!
Basically the outlet of the tap is 3/4" - what I want to have is an adaptor to screw onto the 3/4" thread that will allow a quickfit hose to connect. This way if I need to use the tap to fill a bucket or watering can - the hose can disconnect. Whenever I have tried these they always weep on the 3/4" thread - I have also tried adaptors that are rubber and use compression to fit but have the same problem after a while. I had thought this problem might be because I have used cheap poundland adaptors in the past.
Today I have bought a Hozelock adaptor in metal and still have the leak at the top of the adaptor. The tap comes with an adaptor that provide a 1/2" stub to slide the hose on, but this means its difficult to remove the hose from the tap.
Anyone have any suggestions on what I am doing wrong?
