Outside tap not on straight
EliteHeat said:
Get some loctite 55 - about £3 - allows a complete back turn when fully tight without leaking - yay!
£3 where do ya get yours from :oops:
I know this is a very old thread but in case someone is looking for the right answer then you need one of these: then you don't need all that messing around with tape etc.
This is good stuff and not as expensive as Locktight.
Past on so that tao is straight. Can be still loose. Give 5 mins and it will be watertight and will not move
Todays Tools That Rapid Blue Stuff Anaerobic Sealant 250ml Bottle https://amzn.eu/d/56xPR9m
Has Bosswhite been improved? I thought at one time you had to use hemp with it, and with hemp it was no good for gas, as porous.
No idea, tbh I only looked it up as I thought you couldn’t use boss white on potable water (seems TP website could be inaccurate), we used to use boss green for this purpose.
