Oven Element - no earth tag?
24 Sep 2005
Just looking at espares ... Noticed this :-
2300 Fan Oven Element with 2 terminal tags
This is an easy fitting part and fixing your oven yourself will save you money. This is a genuine spare part - and will fit select Bosch, Neff and Siemens fan ovens that are listed below. Measures 250 mm in length and 2 turns.
Please note: due to new UK standards this part no longer has an earth connector.
Possibly dodgy advice? I wonder just how folks will terminate the loose earth lead... If at all.
The casing of the oven element is most likely screwed to the oven cavity, thus grounding it.
This is similar, includes the 'earth tag' as shown.
Yes, the plate and element supports all fix to (Neff) oven frame... Virtually resistance free from any metal in or on frame to plugtop earth prong... Always been this way.
I wonder how leaving the tag off can be safer with the possibility of an unterminated earth lead hanging loose near L and N connections? In the event of poorly fixed element plate and (or not) support screws what then? I thought 'twas about quickly getting enough current flowing to trip breaker in the event of a fault to earth.
Think I'd be drilling the plate and fixing an earth tab... I am betting the element design hasn't changed...
-p-
