Hi, have recently had a new cu fitted & meter tails. Also new double oven (5.5 kw) with a 32amp breaker (trip ?) to a new 45amp ccu with 10 mm cable & 10mm cable to oven.Now want to fit a ceramic hob(6kw) less than 2m from oven. can i use the same new 45amp ccu with a 10mm cable to hob if so will i have to upgrade the 32amp breaker and what too.thanks.
hope iam replying correctly. thanks luminiare and its yes to your question
