Just a bit of guidance from you kind chaps if poss.
I have just bought a new double oven which is 4.8kw to replace my current single one which just plugs straight into a normal socket. So am I right in thinking this now needs to be on its own circuit back to the consumer unit and with an isolator switch in it as well?
Problem is I have a electrician mate who I was gonna get to do this all for me so ripped the old one out only to realize he is away for a week and will no doubt be busy when he gets back.
My plan is to get everything in place so he can quickly just wire it up.
The run to the consumer unit is only about 3 meters max. I think I am right in using 6mm cable and I was going to fix a 45 amp switch to the wall next to it to isolate it. Also do I get a 32amp or 20amp for the CU?
My other worry is the main switch in the CU says total load not to exceed 80amps. Currently it has a 40amp, 6amp, 6amp, 16amp, 16amp and 32amp will it be ok to add the oven to this?
Sorry if ive gone on a bit thanks.
