Hi all before I get a sparkie in I want a bit of advice on whether I would be wasting my time!
I have a dedicated cooker switch with 13amp plug and 45amp isolator running off a 32amp mcb
it is also powering a 13amp socket for the extractor
The oven states it can be run off a 13amp plug
I have also found behind the wall the wiring has been extended with chocy blocks and taped up see pic below
Ideally I would like to replace the 45amp isolator and replace it with a double gang socket and run the wiring down to another socket which would be in a cupboard for the oven and reducing the mcb to 20amp?
Is this a viable option and should I be looking at a better solution for the chocy block?
Any advice or recommendations welcome
