Overflow pipe on bottom of toilet cistern advice
30 Aug 2005
The downstairs toilet has been moved ( due to extension) and the toilet was plumbed back in but not to an exterior wall...
The over flow pipe on the close-coupled cistern comes out of the base of the cistern, not the side, and is now a fair distance to the outside wall.
Therefore... can the overflow pipe be fitted to the soil-pipe ? If so how..
..Or... can a syphon with a built in overflow be fitted in the cistern... if so is there any way the overflow hole at the base of the cistern can be plugged ?
Hope this makes sense... Cheers
Yes, you can fit a syphon which has a shorter column which then will let it overflow internally down the pan. You then need to get a stopper to block up the hole where your old overflow exited the cistern.
