Well, I have to say - if the coolant level is stable now then lets not panic too much. If the car was mine I'd keep a very close eye on those levels, and see what happens.
So - the cooling fan should come on in the region of 90 deg C.
Under normal circumstances whilst driving along, there should be enough air rushing through the radiator to keep the temperature down, and the fan off. Once in traffic though, the fan will likely come on.
If you feel at anytime the engine is getting too hot when you are driving, put the heater on fully hot and switch the internal fan on. It will roast you, but it will keep the engine happy!
Lets face it - the engine can run as hot as it likes, so long as it doesn't dump its coolant on the ground.
Stay in touch!!
John
Stay in touch!!
John
