Hi All, I'm about to start a loft conversion and about to fit the steel work. I have 2 x 10400mm 203x133x30kg steels (spliced) that run the length of the bungalow and these are bolted to 203x102x23kg beams that run in line with the gable ends (acting like lintels running over windows/doors).
My question is, when fitting the beams into the gables, is it best to leave a gap running between the beam and brickwork so they are bearing onto the padstones only, or shall I run a bed of mortar for the beam to sit on aswell? Thanks.
