Puller, look at the MIs, what is the minimum resistance the thermistor is going to indicate i.e. at max temperature.
That will be value of the resistor you need (Ideal Icos 85 degree resistance value is 1k)
25 degree resistance is 9k7 to 10k3
I would pick 1k resistor and 10 k pot. Solder the resistor to middle connection on the pot. connect one (test) wire to other leg of the resistor and another (test) wire to right hand connection on the pot
Minimum setting would indicate 85 degrees and full travel of spindle on the pot about 25 degrees.
If you want reverse reading, move the outer wire to the tag that is 'spare'
