always use a heat gun then treat with stripper solution, then sandpaper.
Why can't you remove doors? You will presumably get a much better job done if you do......
How GOOD Paint Removers Work on multiple layers Paint removers work by penetrating the coating, breaking chemical bonds, and softening or swelling the paint film so it can be scraped off. They do this in two main ways: 1. Solvent‑Based Paint RemoversThese are the fastest and most common. They...
