It's the thick paint causing suction. Simply thin it down 10& and give it a quick wizz over or use a brush. Don't understand why you keep making the same mistake over and over again.
I've done it loads of times.
You get the same problem with poor adhesion with plaster skim.
Scattycat,
Welcome to the finishing trade, not always easy is it. Yet the more mishaps of which you encounter will be the learning curve of which we have all been through, and perhaps you may not believe it now. Those learning curves can make you a far better P&D.
Dec
lol. I'm not having the problem on every ceiling job I do, but the failure of the current surface seems to becoming more frequent. So I was wondering if the 'new build's' I do sometimes and some (not all) seem to have this problem because they wack them up so quick ?
I don't think it's my technique?![]()
Wonders~~ Have the ceilings you have problems with been previously painted ?
If not previusly coated : Are you applying NEAT emulsion to BARE Artex?. Bare Artex should be mist coated. Thinned down upto 50%![]()
Most new builds with artex ceilings are normally found to be Bare Artex.
Jiust wondering.~~![]()
Good luck
[I don't think it's my technique?![]()
