    Dismiss Notice
Painting prep for going over old walls
Discussion in 'Decorating and Painting' started by mccben9, 10 Jul 2021.
  1. mccben9
    mccben9
    2 Apr 2017
    19
    Thanks Received:
    Country:
    I've stripped the wallpaper in our master bedroom and rather than getting it reskimmed we are going to clean/sand/fill holes etc.
    Could anyone give me any good tips on doing this to get the best finish? Obviously the best thing would be to get it reskimmed but that's not an option at the moment.
    Is there a particular paint we can also use that's quick thick to ensure that it helps to 'level out' any chips etc?
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    72,768
    Thanks Received:
    4,168
    Crossgates, Europe
    Country:
    Cook Islands
    No.
    • Like Like x 1
  4. mccben9
    mccben9
    2 Apr 2017
    19
    Thanks Received:
    Country:
    Thank you, so helpful
  5. Chivas69
    Chivas69
    30 May 2013
    220
    Thanks Received:
    48
    West Midlands
    Country:
    Could you put lining paper up first?
  6. Sponsored Links
  7. mccben9
    mccben9
    2 Apr 2017
    19
    Thanks Received:
    Country:
    Thank you! I haven't heard of this so will have a look. I thought lining paper was just for wallpaper though?
  8. Chivas69
    Chivas69
    30 May 2013
    220
    Thanks Received:
    48
    West Midlands
    Country:
    No you can get it in higher thickness and when on treat it as a flat plastered wall. I think toolstation have 2000 grade at about £6 for a double roll (20m)
  9. jacko555
    jacko555
    5 Feb 2005
    538
    Thanks Received:
    70
    Country:
    I have done this in my front room. I didn't want lining paper. Unless the walls are in a very, very good condition, it is a massive undertaking, however, doable, if you have a lot of time, patience and don't mind a lot of dust and disruption.
    My house is 1920's, lime plaster walls. 9ft ceilings. For the front room, 90% of the plaster was sound, however, blown areas around the windows due to rotten leaking windows. The existing plastering looks level, however, running a hand down a length you can feel the undulations. Pretty much like any plastering from that period.
    What I did:
    Stripped the wallpaper / tile adhesive.
    Washed with sugar soap.
    Filled all holes and damage from removing the wallpaper, with toupret filler. Use this, not a cheap filler. If properly sanded, you cannot tell where the filler was.
    Removed blown plaster, used bonding coat around windows to bring near level, then, toupret.
    For minor dings and scratches (less than 2mm), I used toupret fine surface filler.
    At this stage the surface of the walls were 90% filler.
    Sanded it.
    Second round with filler. Sanded it.
    Painted it with Farrow and Ball Estate emulsion.
    Use a very, very matt paint FB Estate emulsion is 4% sheen. This helps to hide imperfections.
    Went around the room with a lamp on the floor, pointing up at the wall. This highlighted even more imperfections I missed.
    Cursed every previous owner of the house for the century of holes they'd drilled and filled.
    Filler.
    Sand.
    Filler.
    Sand.
    Cursed myself for not being more careful stripping the wallpaper.
    Keep going until you cannot see more imperfections.
    View the room in different lights. The morning light and bright sun will expose more imperfections.
    Filler.
    Sand.
    Curse.
    Add second coat of paint.
    Vow to never do this again.
    Tips:
    Don't do it.
    Use toupret filler.
    Properly sand the filler and feather the edges of holes. Use decent sand paper and a block.
    Inspect in different lights.
    Use a very matt paint.
    It now looks beautiful and looks like the original walls are in great condition. You cannot tell the new bits from the old.
    I did this gradually during lockdown when I couldn't get a plasterer, and, it took a long time. It also cost a lot of filler and sandpaper.
    Unless your time is free, and, time is of no concern, use lining paper, or, get it skimmed.
    Since then, the WC has been skimmed by a plasterer as it was similar condition. I, against my better judgment, stripped the wallpaper in the bedroom, and, used toupret. The walls were near perfect so it only took 2 cycles of filler and sanding before painting. Took a few days. Nowhere near as traumatic.
    • Like Like x 2
  10. mccben9
    mccben9
    2 Apr 2017
    19
    Thanks Received:
    Country:
    Thank you!! We have been working on the front room now and it's not TOO bad. Unfortunately one of the alcoves is a total mess and the adhesive is so stuck. I've heard there's a product called Dif which is meant to be good for removing it but also was advised it's for professionals (which I am not) and not to use it. We haven't used toupret on this room as I've only just seen your reply so hoping the polyfilla will be ok! Haven't finished the bedroom yet but comparing it to the front room the walls are MUCH better. Apart from all the wall plugs that are totally stuck!
Loading...
Share This Page
