    Dismiss Notice
Park Homes - Caravan or Building
Discussion in 'Electrics UK' started by gadget300, 27 Aug 2012.
  1. gadget300
    gadget300
    17 Apr 2010
    17
    Thanks Received:
    Hampshire
    Country:
    Hi, my parents have just moved into a park home and need some major work throughout the place. Some electrical work will be required including new circuits but I am at a quandry with the regs. Do park homes which are essentially a wooden caravan that doesnt move fall into a normal building installation catergory or do they need to be considered as section 7 special locations? whats you thoughts?
  2. Sponsored Links
  3. Lectrician
    Lectrician
    18 Jul 2004
    8,503
    Thanks Received:
    405
    Devon
    Country:
    No they are not a special location in themselves - Take a look at the definitions in the front of the regs for "Caravan" and "Leisure Accommodation Vehicle".
    And also, in section 721's scope, see:
  4. 333rocky333
    333rocky333
    12 Jan 2008
    8,424
    Thanks Received:
    902
    Essex
    Country:
    If you have the regs book see if it comes under the "scope" sections of section 708 and 717
    Would the home be deemed as transportable
  5. gadget300
    gadget300
    17 Apr 2010
    17
    Thanks Received:
    Hampshire
    Country:
    Thats what I thought yet the whole supply set up to the unit is as if it were a caravan. A small enclosure on a pole before the home with an RCD covering the whole installation, and only a 6mm 32A supply to it as well. No good for the electrica hob and double oven they wanted!!!!!!!!
  6. ericmark
    ericmark
    27 Jan 2008
    18,585
    Thanks Received:
    1,744
    Llanfair Caereinion, Nr Welshpool
    Country:
    I would not have been looking at 17th Edition but to Part P building regulations and the first question has to be "Is it a building"?
    If it's not a building then clearly not under building regulations. I would not think it's classed as a building but much will depend to if it is considered portable and if it under road traffic regulations could be transported.
    Sorry can't really answer question but I would be looking at other items not 17th Edition.
  7. Sponsored Links
  8. viewer
    viewer
    2 Apr 2005
    772
    Thanks Received:
    52
    Country:
    Might be easier to check the planning permission for the park as that will state if they are required/considered to be temporary/moveable. Site owner or council will be able to tell you. There may be some reference in their agreement to lease the land.
  9. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    [​IMG]
    "Building" is irrelevant.
    The question is is the structure a "dwelling"? If it is then Part P applies.
    And we all know what the easiest way is to ensure compliance with Part P.....
  10. SparkyTris
    SparkyTris
    24 Nov 2004
    406
    Thanks Received:
    4
    Country:
    My dwelling is a small tug-boat. Does part P apply to that?
  11. OwainDIYer
    OwainDIYer
    5 May 2010
    4,554
    Thanks Received:
    698
    Stirlingshire
    Country:
    Does it depend on whether the tug-boat is registered in Orkney?
    Are you flying an Orcadian flag of convenience?
    Would you be claiming Udal Law applies?
  12. ericmark
    ericmark
    27 Jan 2008
    18,585
    Thanks Received:
    1,744
    Country:
    For the tug boat likely different but narrow boats come under the RCD rules. Lengths and use can of course change what rules apply.
    Part P is of course part of the "Building Regulations" and so it has to be considered a building. So Part P does not apply to boats.
    However to be classed as a caravan it needs to comply with the construction and use regulations which limits width and lenght. Section 721 does not apply to the electrical installations of mobile homes, residential park homes and transportable units.
    I am sure Part P will apply in this case as really they are no different to the prefab homes build in the 50's it does not really matter what the name is they can't be hitched up and towed down the road.
    I would say they come under same rules as a house. But without being certain to if they are road legal or not can't really answer. Wheels used purely to assist getting it off the wagon don't make it a caravan. However I have seen pairs of caravans designed to be towed to site and placed next to each other with all the lights etc required to tow them. These would not be classed as a building.
    There are problems either way. If a caravan you can't use twin and earth or a TN-C-S supply. Also all the warning notices would need to be in place. My son said many times with his boat why does a boat need to have a notice to say where items are when you live on it. As you come into my house the is not a notice by the front door saying how to switch on and off power as shown in Fig 721. You can't have it both ways. Electrical condition reports every 12 months instead of 10 years.
    I would lay odds it's classed as a building. But the LABC may not want to class it as a building. If they do then it means the site owners have to apply to the LABC to change where they are erected and also provide roads and access like with any other housing estate. They are a law to them selves so it may be worth asking them. I would write not phone as they may change their minds and you want proof as to what they said.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
