    Dismiss Notice
pathetic DIYer can't fix tap!!
Discussion in 'Plumbing and Central Heating' started by torpor, 5 Mar 2014.
  1. torpor
    torpor
    5 Mar 2014
    3
    Thanks Received:
    Bradford
    Country:
    I have a dripping tap. I successfully remove outer casing etc to expose brass fixture. I can't for the life of me get that to move in either direction. Clockwise or anti clockwise. Is it because I am weak and pitiful? Should it move easily or should I get a stronger friend or wife to do it. Or a plumber??
    advice please.
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    23,144
    Thanks Received:
    4,500
    Northumberland
    Country:
    If you have exposed a brass insert with a hexagon to turn, then get a bigger spanner and turn anti clockwise.
    Your biggest issue - if its a monoblock tap or a single unit - is stopping it spinning on the basin......avoid that or it may leak below.
    John :)
  4. torpor
    torpor
    5 Mar 2014
    3
    Thanks Received:
    Bradford
    Country:
    Fingers crossed then. Thanks for the speedy help. Cheers
  5. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,766
    Thanks Received:
    141
    Gwynedd
    Country:
    Turn off the water first.
  6. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,384
    Thanks Received:
    1,736
    Northamptonshire
    Country:
    If it's in a basin (or any chinaware fitting) then be careful you don't crack the said fitting..... :eek:
  7. torpor
    torpor
    5 Mar 2014
    3
    Thanks Received:
    Bradford
    Country:
    Well...I hadn't thought of that one, but thanks thats great advice!
  8. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
