patio fall
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
can anyone help me out with the falls ratios.
i have a patio which is going to slope from the house to the grass in one direction only. the distance from the house to the grass edge is 6m. what fall do i need ? currently i have done it to allow a 2cm fall.
is this enough. not sure what 1;40 actually means. is this 1cm for every 40 cm ?? i am stumped a bit and i think i have not made a big enough fall.
The fall you describe is 1 in 300.
6mts = 6000mm and 2cms = 20mm, so 6000 divided by 20 = 300. ie. for every 300mm the fall is 1mm.
I think thats a bit shallow, I'd go for 1 in 150, so over 6000mm that would be a fall of 40mm.
And you really need a drain to take the water away.
if i dig a channel into the grass and fill it with gravel, will this be enough to drain the water away?
what will happen if i do a patio with a shallow fall like this ?
the spirit bubble will be at the back of the line and so it will be draining ok.
Your channel idea sounds ok.
A 1 in 300 fall will drain, the main problem would the difficulty in maintaining the fall whilst laying the patio. But if you're very careful and use slabs with a complaetely flat surface it should be ok.
It may last a couple of seasons. Maybe.
It will depend upon your sub-soil drainage. A foot deep channel of gravel will clog up after a couple of years.
A well built soak-away can last in excess of 25 years.
