Hi Guys, Just wondering if rubber grommets have to be fitted to the metal back boxes? is this a 'should do' or is it a must?
Not important, once plastered the cable cannot be damaged, and if in dry lining the cable is not moving about once everything is finished.
I take holmslaw's point, however don't forget that cables do vibrate in service.
Nothing.What do you do if the boxes are already plastered in, i.e. there's no way to get a grommet to fit in there?
You'd need to be pretty picky to do that. If I understand you, the cable is embedded in plaster up to and including the hole in the box, which is why you can't get a grommet in, in which case the cable can't move around and chafe on the edges of the hole.Will this be flagged up on a PIR,
Again - if the plaster is where I think you're saying it is then how could you get anything round the cable which would go through the hole and out the other side?and is there any other protection (i.e. shrinkwrap) which should be considered instead?
But it was a new socket back box that was being installed, a grommet should be regardless of the fact it is getting plastered over.
When I was doing my Inspection and Testing course work, I was told to inspect for missing grommets!
